Start by aiming it at 9 degrees on a compass (you can get one for about $5 at WalMart or any sports store). Then do a scan on your tv (making sure your scanning for either "OTA" or "Antenna"). Make a list of what you get and don't get. If that doesn't get you everything you want move the antenna a little bit towards the direction of the station you want but don't get. Be patient. You may need to make several adjustments, and even move the antenna up and down on the pole. [Come to think of it, I'd try it in several different places on the roof before mounting it, if you don't have only one place to put it.]
