Old 10-Mar-2015, 4:02 PM   #14
Tower Guy
Originally Posted by 2CfreeTV View Post
I've been looking around for the amplifiers.
What would be the best to worst of the lot? Should I avoid anyone
of them?
Is there any major differences between any of these?
All of those amplifiers will be overloaded by WRPI on 91.5. The WRPI tower is less than a mile from you. Overload will make reception worse, not better. Most FM traps are not effective on the low end of the FM band. Antennas Direct sells an FM trap that works at 91.5, but it won't pass channel 6.
Your problem is that you have an antenna that's not designed for WRGB, in a poor location, aimed the wrong direction, and perhaps unrealistic expectations.
