I am not using an amplifier so I suspect the multi path due to rugged terrain is more likely the issue. The antenna I am using seems like it has directivity. What specific antenna do you suggest?
The reason I don't use an amplifier is that the transmitter is only 9 miles away. Is that false logic?
