Thread: Newbie question
Old 9-Mar-2015, 7:48 PM   #9
mars1162
Finding a balun
http://www.solidsignal.com/pview.asp?p=CM9444 DeeJay try this site and you can also see what it is. A balun is just a shorter word for balanced to unbalanced. What it does is match you antenna's impedance to the impedance of your coax and tv. Impedance is measured in ohms. That is why you need something to match your antenna which is 300 ohms to your tv and coax which is 75 ohms. Balun = matching transformer. There are lots of ways to make things match but this is the simplest and cheapest way to go. When you get on solid signal site I am sure you can find some coax there also.
mars1162 is offline   Reply With Quote
