Old 9-Mar-2015, 11:19 AM   #21
eggman531916
I made the error.
The error was made when didn't double check where my 12 year old son was holding the tape measure. I just assumed it was in the right spot. I chalked a line and started cutting through 75 inches of 1"x2"x36" fencing. It was about 2" off. Basically, I'm using original sized elements (7" zigzags w/ 5.6" stubs), 88mm spacing between elements, 5" spacing between bottom of top element and top of bottom element. Planning on using 2" spacing between the transmission lines, 1"-2" in front of the elements. I don't have an acual link, I'm just going by what I've read here and there on the forums. If anything in my plan sounds faulty, by all means, please tell me. Thank you.
eggman531916 is offline   Reply With Quote
