Old 7-Mar-2015, 9:04 PM   #2
You're correct, you'll have the best success with NYC signals if you use an outdoor antenna of combination of antennas.
A basic option would be to point a Winegard HD7698P or Antennacraft HBU-55 west, toward NYC.
If you want to try to add WJLP to your line-up, consider the Winegard HD7084P instead.
I'd expect some of the stronger signals from the NE to be received via the rear of those antennas.
I'd use an Antennas Direct 'Juice' preamp if you were to connect two or more TVs or have more than 50' of coax from the antenna to a single TV.
