You have a good TV Fool Report. It is unlikely you would need an amplified antenna. Others will comment on better options for an indoor antenna (probably a Terk HDTV-A).
Do you have a south facing window or door? If yes, aim your antenna through it (if there is a metal screen take it off first). See what difference it makes on your problem channels. [What are your problem channels and are in the in the direction your antenna is pointed in?]
What is your apartment building made of? If it's stucco (for example) that can kill the signal that gets to your antenna.
