Old 6-Mar-2015, 5:43 PM   #13
As long as the cable tie has some type of UV protection you should be fine. My only complaint re the Home Depot CE brand cable tie is that they get brittle when cold. That has caused trouble when installing them in low temp conditions. Once they're in place, and not disturbed, they don't crack or break due to cold weather.
The pricey Panduit product has always remained flexible at any temperature I've worked in. If you have moderate temperatures during installation, you won't notice a lot of difference between the two products.
