Trees can be an issue, causing intermittent signal loss when the limbs and foliage move in the wind. When not moving, trees will cause some attenuation, but your tuner is able to adjust for slowly changing signal levels (within a finite range of power levels).
I'd consider a Winegard HD7694P or Antennacraft HBU-44. If CBS is the highest priority, point the antenna NE. You can also experiment with aiming west, and still expect reception of the NE signals through the rear of the antenna... You would need to decide which aim point provides the best overall reception reliability.
