Old 5-Mar-2015, 7:03 PM   #4
The terrain between you and the Sacramento area is more formidable. I don't see the Sacramento signals being a viable option at your location.
When you look at your TV Fool report, you'll see a column titled 'NM (dB)'... as that number drops below zero, you are at a point where reliable reception is going to require the use of extreme measures. As the NM value drops into double digit negative values, intermittent reception would be the the most one could reasonably hope for.
