Old 6-Jan-2011, 7:28 AM   #7
John Candle
Tv Antennas and Reception
You say that money is tight , so I am doing my best to get you as many channels as possible with the antenna you have for the least amount of money. Will you receive every last one of the line of sight channels?? The answer is No. . The channels marked as co-channel warning and adjacent channel warning will likley not be received with out sharply directive antennas and that means more money. . Always look inside the connectors on the ends of the coax , if the foil shield or shield wires are pushed in toward the center wire , push the foil shied and wires away from the center coax wire.
