Old 5-Mar-2015, 4:39 PM   #4
I'd try without any amplification, running this test during the install process. If the need for amplification is proven, a preamp or distribution amp can be inserted at any time.
I'd avoid 'deep fringe' high gain amps like the CM-7777 and PA-18... Both are for speciality applications where there are exclusively weak signals present.
The Antennas Direct 'Juice', RCA TVPRAMP1R and Channel Master CM-3410 would be better suited to your application.
