Old 5-Mar-2015, 5:21 AM   #3
keller525
I'd opt for an outdoor mounted pair of antennas such as an Antennas Direct DB4E and Antennacraft Y5713. I'd do all that I could to avoid aiming trough trees and structure(s).
If you are unable or unwilling to consider any option other than attic mounting, and you can only consider a single antenna, then I'd suggest trying the Antennacraft HBU-33. If your attic turns out to be a poor reception location, the HBU-33 can be re-folded and moved outdoors.
If driving a single tuner trough 50' of coax, no preamp should be needed.
Thanks for the recommendation. Unfortunately, I am limited to an attic installation. Do you think I will need an amplifier if I use a splitter for two televisions?
keller525 is offline   Reply With Quote
