Rotating an antenna might make sense if you were going after every possible signal... But then you wouldn't be considering an attic mounted antenna. If you are limiting yourself to an attic mount, I see no point in adding a rotator.
A panel antenna such as the DB8E is certainly not 'long' and not a Yagi type. The Y5713 is not what I would consider 'long', but if it won't fit your situation, you could opt for the Antennas Direct CS5, which I believe includes a UHF/VHF combiner.
