Old 4-Mar-2015, 12:44 AM   #2
I'd opt for an outdoor mounted pair of antennas such as an Antennas Direct DB4E and Antennacraft Y5713. I'd do all that I could to avoid aiming trough trees and structure(s).
If you are unable or unwilling to consider any option other than attic mounting, and you can only consider a single antenna, then I'd suggest trying the Antennacraft HBU-33. If your attic turns out to be a poor reception location, the HBU-33 can be re-folded and moved outdoors.
If driving a single tuner trough 50' of coax, no preamp should be needed.
