Old 3-Mar-2015, 2:18 PM   #3
jmsteele
Thanks for the info. Are there any antenna models you could recommend that might work better than others ? I've used the Wineguard FV-30BB FreeVision in the past at my other location with good results. A dealer recommended the Winegard Metrostar VHF/UHF Amped Omnidirectional.
I could probably get setup pointing SE however there is a building about 75 feet away in that direction.
Thanks, Jon
jmsteele is offline   Reply With Quote
