Pre-amp & distribution amp layout confusion!
Good morning.
I currently have my antenna setup with a (TITAN 2 HIGH GAIN PREAMPLIFIER CM7777) as follows:
(Antenna > CM7777 > 2 Way Power Pass Splitter > 2 Televisions)
I would like to install an (ULTRA MINI 4 CM3414) so I can add 2 additional TVs for my children’s rooms.
Both the Pre-amp and Distribution amp would need to be in the attic away from a power supply. This was not a problem with the pre-amp as I was using the supplied power inserter and I understand that I can also use a power inserter for the distribution amp. I am having trouble figuring out how to power both amps without splitting the feed from the pre-amp at least once. I would prefer that 100% of the pre-amp signal be input into the distribution amp but can't see how when using power inserters.
Any help would be greatly appreciated.
