Old 2-Mar-2015, 12:13 AM   #3
siglouie
GroundUrMast,
Thank you for your reply!
I appreciate the information you have provided, and I've learned a few things along the way!
Mounting an antennae outside is not an option.
I am limited to using an indoor antennae, however, I am able to position an antennae on/near a South-facing window, if this helps.
Do you think a different antennae would improve signal reliability?
Can you recommend an indoor antennae that may improve reception? Perhaps a flat antennae that I can secure to a window?
I have seen a few flat antennas available from Solid Signal,
eg: (Solid Signal HD-BLADE Indoor Digital Flat Clear Indoor TV Antenna(HDBLADE100C))
Would this antennae be an improvement over the Philips I'm currently using? (see above post)
TIA,
siglouie is offline   Reply With Quote
