Old 28-Feb-2015, 3:49 PM   #1
siglouie
Intermittent reception question(s)
Noob here.
Glad I finally found this place!
I've surfed the boards, and I'm still confused.
I'm uncertain as to what I need for uninterrupted/unfettered reception.
Do I need a pre-amp/amp, or do I need a better antennae? Or both?
Here are the details...
I live in a 10-unit apt. building and I'm restricted to an indoor antennae, with windows facing South. For the most part, my reception is good. However, high-winds, overcast skies, and precipitation, all have a negative effect across the spectrum of channels I typically receive on a clear, windless day.
Currently, I'm using a PHILIPS SDV5119 antennae (near the windows), connected to approx. 15 feet of coaxial cable, which is connected to a Zenith converter box, then through a 3-feet piece of coax to the TV.
(I seem to receive better reception when using the Zenith converter box, as opposed to connecting the antennae directly to the TV.)
Here is my TV FOOL Signal Analysis info:
http://www.tvfool.com/?option=com_wr...f1f0ada1f2b4ab
Channels I 'lose' when issues arise are:
6-WPVI
2-KJWP
69-WFMZ
As mentioned above, reception for these channels is generally good, when the skies are calm and clear. However, even on clear days, I often have to re-scan the Zenith box, to re-acquire the channels, if they're lost.
Should I invest in a new antennae, amplifier, or both?
Or am I stuck with what I have?
Thanks for your time!
siglouie is offline   Reply With Quote
