Old 27-Feb-2015, 6:04 PM   #2
Tower Guy
Hi Jerry; Your channel 41 notch filter can work. Such filters are custom made by Tinlee in Toronto, ONT or Microwave Filter in Syracuse, NY.
Another approach is to use an antenna that drops the level of channel 41 below the overload point while it is aimed at the other UHF stations. In your case the main stations that you want are 30 degrees off axis from channel 41. One specific model antenna has a null at 30 degrees, the DB-8. (Not the DB-8e). Then get a preamp such as the TVPRAMP-1R. Continue to use your existing antenna for VHF.
