Old 27-Feb-2015, 4:31 PM   #1
Jerry37857
pre amp overload?
Greetings,
Hopefully this link to the signal analysis works:
http://www.tvfool.com/?option=com_wr...2c15283eaefed4
As you can see channel 41 is very strong while the other channels are weak. My concern is if I add a preamp at the antenna the amp will be overloaded by channel 41. My thought to avoid this overload is to put a trap between the antenna and the pre amp. If this is the proper course, add a channel 41 notch filter, the next question is where do I buy one of those?
The antenna is a Channel Master extremetenna 80.
Bandwith 174 to 216 and 470 to 700 MHz
VHF Gain 5dB
UHF Gain 12dB
Front to Back Ratio 18dB
Impedance 75 Ohm
Regards
Jerry
Jerry37857 is offline   Reply With Quote
