Old 25-Feb-2015, 8:01 PM   #5
bigl523
Thanks for the replies. Here's an update (sort of).
When I setup the antenna in the attic, I was getting all 4 channels perfectly. It seemed that everything was great. The next day I began having the problems with FOX and figured it may be something with the antenna from FOX because I was getting NBC which is right next to the other antenna so I didn't move the antenna. I have an appox. 25' foot factory crimped coax that I bought from monoprice years ago. Antenna to tuner is setup as follows:
Antenna -> transformer -> short cable run to preamp -> 25' cable to pre amp power device -> short cable run to HDHomerun network tuner
I have no splitter's in this setup other than the powered preamp components. I'll go up there tonight and try moving the antenna around. We are kind of out in the woods and the antenna is pointed directly at a metal gable vent on the side of my house so that may be an issue.
bigl523 is offline   Reply With Quote
