Thread: Chch
Old 25-Feb-2015, 4:49 PM   #27
It looks like you've listed virtual channel numbers rather than the real channel numbers, If that's the case, you're having problems with the weakest signals only. The best suggestion I can offer is to experiment with alternate antenna mounting locations & height.
You could also try replacing the LNA-200 with an Antennas Direct 'Juice' preamp which has a solid metal housing which provides nearly perfect shielding. But as always, reliable reception depends first and foremost on the antenna producing a quality signal at it's output. An amplifier won't do the antennas job.
