Old 25-Feb-2015, 4:39 PM   #4
One of the most effective tools available to the DIY antenna installer is a known good cable that can be used to bypass a suspect component. For less that $20 you can get a 50' cable with factory installed connectors and an F-81 barrel connector. These two parts can greatly simplify trouble shooting.
Example: http://www.homedepot.com/p/CE-TECH-5...0-ft/203717795
http://www.homedepot.com/p/CE-TECH-T...0-WH/204267367
With the 'tools' mentioned, and a good TV tuner, you have all the parts need to run this test, http://forum.tvfool.com/showthread.php?t=13646 as well as trouble shoot the other possibilities listed in the previous posts.
