Old 25-Feb-2015, 2:50 AM   #1
bigl523
Help getting Fox (WTIC-TV)
http://www.tvfool.com/?option=com_wr...f1f04ea1279087
I get CBS, NBC, and ABC but am having problems getting FOX (61.1 WTIC-TV). I don't understand as the NBC antenna is at the same azimuth as NBC 30.1. 61.1 the signal strength is 81% but the quality jumps from 0 to 10 to 36. Could it be a problem with the antenna thats transmitting? I have a Channel Master CM-3018 (60 mile range) located in the attic with a winegard boost xt preamplifier. Without the preamp I get diddly squat. It's pointed at more or less 340 degrees. Thanks in advance.
bigl523 is offline   Reply With Quote
