Old 24-Feb-2015, 11:43 AM   #7
No static at all
No static at all's Avatar
Originally Posted by rafulton1944 View Post
In my graph all major networks (abc nbc cbs fox. Pbs) are in green. Is it not likely that they would be viewable with a set-top antenna?
Rich
Very doubtful you will see any channels reliably with a set top antenna.
At the very minimum you will need a good attic mounted antenna. Hard to say how well it will work w/o trying. I would say you have a 50/50 chance at best.
I agree with the HBU 55 recommendation if you want to try the attic first. Check with your local Radio Shack(if they are still open). The HBU 55 is selling for $50.00.
