Rotor
Might be bad coax between the inside control box and the outside rotor. The single layer bonded aluminum shield and thin shield wires can break. I suggest quad shield coax for maximum power transfer from the inside unit to the outside rotor. Also check the center conductor wire of the coax inside the coax connectors , make sure the wire is clean for good electrical contact.
