Old 23-Feb-2015, 3:55 AM   #6
Here's a source for push-up type masts, http://www.3starinc.com/telescopic_masts.html Just to give you an idea of the cost involved.
The path profiles links in your report show fairly level terrain so getting an Antennas Direct DB8E above the tee tops could deliver the signals you've mentioned... Though it would be good to see a TVFR based on the height the trees dictate.
