Old 22-Feb-2015, 11:30 PM   #1
breakerwannab
Red face Need help on antenna choice
Hi would like to be able to pickup all the major networks abc, fox,nbc,cbs if possible without rotator , I live in northeast Connecticut with zip code 06239 and will be mounting the antenna on top of my roof with about a 10 foot pole, I'm looking for a long range antenna that can go 180 degrees and pickup up both uhf and vhf. according to the signal analysis all the major networks within 50 mile radius is in four different locations , Do I need two identical long range antenna that goes 180 degrees and put them opposite of each other if so what do I use to combine the antenna? a coupler or splitter/combiner or they both the same thing and should I use amplifier for both, I had an antenna with a rotator but was only picking up 3 stations and none were the major networks.
breakerwannab is offline   Reply With Quote
