Old 22-Feb-2015, 5:49 PM   #4
You're close at this point... I'd expect some improvement. Unfortunately, the only way to know what the result would be is to try.
Do you have any options to mount higher, even if just for testing? I'd want to find better signal quality in the air, then consider the cost vs benefit of replacing the existing antenna.
