Old 22-Feb-2015, 5:30 PM   #3
brucenh
Thanks muchly for the input.
When I initially installed the antenna I used the handy HDHomerun Cell phone app. This allowed me to see what the actual readings were on the HDRH unit. I optimised its position according to these readings. (Lowering the antenna as you suggested was actually better)
After my lack of success with the Chek signal I decided, probably wrongly, to try the amplifier.
On cloudy days everyting improves considerably and I can get CHEK fine but on clear days I am now losing both Chek and PBS.
So, assuming a strongly ampliifer will actually not help but make things worse. Do you think something like a DB8e would do the trick and get me over the magic 60% or should I just abandon the attempt?
Cheers
brucenh is offline   Reply With Quote
