Old 22-Feb-2015, 12:40 AM   #2
timgr
Did you select 15' elevation for a reason? That is very low. For a cabin, I would expect it to be surrounded by trees. With that report, to get anything, you'll need to be above the trees, and that implies higher than 15'.
I'd only expect to have a chance to pick up the top 4 stations on your list... and W45BT is a repeater for WPCB, an evangelist station. And those lowest signal levels are dicey, even with a premium setup with no issues like trees or buildings.
