Old 21-Feb-2015, 8:39 PM   #1
brucenh
Reception problems in Maple Ridge
Firstly this is a great resource, I have read and learned a lot from it. Thanks to all the tireless contributors.
I am almost ready to cut the cable but i have one stumbling block. The wife loves Jeopardy and I can only get that on CHEK (49).
http://www.tvfool.com/?option=com_wr...2c1509f1ddeebc
Antennas Direct Clearstream C4
Channel Master 7778
HDHomerun Tuner HDTC-2US(CA)
50' of cable from antenna pre-amp to power injector
Initially I started with a homemade antenna as proof of concept. I was able to get all the tvfool green channels no problem, when pointed in the right direction. I was even able to get KVOS(35) occasionally. Since I was more than happy with the results from a 6 coat-hangers antenna I decided to go for a the roof antenna route because I wanted to add PBS(24) and CHEK(49).
After installing the antenna I found that I could get PBS at night and sometimes CHEK. The antenna is pointed at PBS
Because the signals were bit weak I thought I would try a pre-amp. I chose the 778 because I did not want to overwhelm my strong channels.
The first night this worked like a charm and I got good PBS and Chek. The next morning CHEK went away and has not come back. PBS is fine. Strangely I lost KVOS when I put up the antenna and it did not come back with the preamp.
I have tried both turning and moving the antenna up and down. (I found if I go higher I lose PBS entirely.)
From, HDHOME Run - unfortunately they do not give actual values.
PBS
Signal Strength 71%
Signal Quality 58%
Symbol Quality 100% stable
Chek
Signal Strength 64%
Signal Quality 42%
Symbol Quality 0%
KVos
Signal Strength 82%
Signal Quality 42%
Symbol Quality 0%
CBC
Signal Strength 98%
Signal Quality 90%
Symbol Quality 100%
Other notes: There are evergreen trees inteh direction of both PBS and CHEK. I get stronger signals at night. I get stronger signals when cloudy vs clear.
Not sure where to go from here. So far after spending a bunch o money and time I have gain PBS and lost KVOS (not a big deal). So I am really not that much better of than I was with a coathanger antenna.
Any ideas would be appreciated.
Cheers Bruce
brucenh is offline   Reply With Quote
