My apologies. Digital to analog converter.... I had it backwards. It's a Magnavox Model No. TB110MW9. It's the only thing I own that has some sort of signal strength meter on it. When I hooked it up to the TV in question, it gave me the same signal strength on all channels as it did when I hooked it up to the (better?) TV (Viore) in the living room, which is directly underneath (almost identical in cable run length) the problem TV (RCA).
