Thanks.
Im right next to 460, could gently toss a rock and hit it.
18,27,36,46 come in fine, never had an issue really. So far, with exception of my experimenting with the reflector, they come in like cable, day, night, storm, clear skies or blizzard. 18.2 will quickly blip from time to time if a car goes by, mainly in the mornings, but not often, but other than that, it comes in great.
could I combine the xg91 with my existing antenna, that way the 67s still come in? Use the xg91 to enhance the front signals, or 18,27,36,46 and hopefully and mainly 56?
Seems the signal on my diy four bay bowtie has improved since I refurbished it the other day, perhaps a corroded contact was causing the weak signal issues last fall?
Thanks for helping, gonna wait till all this snow is over with before I buy an antenna.
You think two reflectorless four bay diy bowties stacked and combined would improve anything? Or just go with the yagi xg91 and be done with it?
I ask about combing the two, not sure if the xg91 will be able to get the 46,56, and the 27,36,18 or if I should use my existing diy antenna as a filler, and focus the aftermarket piece towards ?
Thanks
