Old 19-Feb-2015, 11:11 PM   #3
inline300
I tried a new report, it didnt acknowledge my address specifically, punched it in a few times. But its closer, the report seems to reflect what Im getting. Attached new report below.
channels Im getting now are:
18.1
27.1
36.1
46.1
67.1
and their sub channels
56.1 and its sub channels would be a nice addition.
I could try the DB8e and I could combine it with my existing antenna, since it seems to bring in the majority of the channels just fine. Just wish, I could be more certain it would in fact do the trick. Im only running 40ft or so coaxial from the antenna, so if I read right, I shouldnt need a preamp. I have a preamp from a mohu leaf indoor antenna, and it didnt help my situation at all, I knew a poor signal would only get worse, good signal better going into it, but had to try. To join two antennas, I just use a simple two into one coaxial adapter?
I ground the pvc mast and I also ground the connector, that joins the outside coaxial with the interior of house coaxial.
How would a person figure out the ideal db8e reflector for my situation?
updated report. Thanks
http://www.tvfool.com/?option=com_wr...cd3fcf2138b786
Thought about trying this:
http://www.tigerdirect.com/applicati...FQKTaQod2poA1w
inline300 is offline   Reply With Quote
