Old 19-Feb-2015, 7:10 PM   #5
enthrop
But to clarify, the amplifier only helps if I'm getting the channel, but it's coming in poorly? On the other hand, if my issue is that I can't even get the channel at certain physical spots, then the amplifier won't help?
I was thinking because I can get the channels I want in different physical spots, if the issue is a weak signal strength that my TV decides it's "not a real channel," then an amplifier might help. But if I'm amplifying a signal that I'm truly not even getting, then amplifying nothing is more nothing
enthrop is offline   Reply With Quote
