PA. DTV reception
I would start easy. Use the simple Bay antenna that I recommended, or a similar one such as the Eagle Aspen. Try pointed in either of the two positions of your stations. Test the results in both. It may work very well. If not remove the rear panel to form a bidirectional antenna. You could add a rotor if needed.
