Thread: Micco, FL
Old 18-Feb-2015, 9:40 PM   #9
Jake V
You are correct that the gain is much less when the two panels are aimed in separate directions. Others will comment, but I think you should get the majority of stations and would be quite happy.
Just thinking. Another possibility is to leave the panels facing the same way and remove the reflector and try to find a sweet spot (your channels are more or less in opposite directions). Others will comment. Maybe a smaller antenna without the reflector could do the job.
You might also do additional reports at 20 and 25 feet just to see.
