Old 18-Feb-2015, 5:56 PM   #2
At first glance it looks like you'll need to get a bit aggressive if you want to include an ABC affiliate in your line up.
I'd use an Antennas Direct DB8E facing south. WFTV looks like the signal I would work the hardest for. Mounting high enough to clear nearby trees may be the only way to achieve reliable reception of the rather weak signal. Consider using the 'Juice' preamplifier from AD... The RCA TVPRAMP1R is a good alternate.
