Old 16-Feb-2015, 10:43 PM   #2
Jake V
Yes, you can use your current signal distribution system left by the cable tv.
I'd use a Antennas Direct DB-8e with one panel aimed at 8 degrees on a compass and the other at about 160 degrees. You will probably not get the Fox station or below. Others can comment on that, as it would require extreme measures.
