Old 16-Feb-2015, 8:33 PM   #1
dalis
Antenna setup feedback
Hi all, starting to find ota very interesting but need to do all the homework before getting into it.
Here is my tvfool report
http://www.tvfool.com/?option=com_wr...2c1542ced04540
I was wanting to install an antenna on the garage approx. 15'-20' above ground, where the shaw cable comes into the pole from the lane. Was looking at using the existing cable (approx. 100' wire; age 8years old) which runs from the detached garage then into the ground and then in the house to a cable box which is split to 7 tvs, via Electroline Drop-amp EDA-FT08300.
Question: Can I use the existing setup and just add an antenna which taps into the cable box at the garage? Which antenna would be best? And if at all possible pickup channels from Seattle
dalis is offline   Reply With Quote
