Old 13-Feb-2015, 1:01 AM   #5
thesoxwin
Originally Posted by Jake V View Post
It depends on what you want, but if this were me I'd go for the channels at the NE and SSW. Almost all of your stations are UHF. For these I'd use a Antennas Direct DB-8e with one panel at roughly 60 degrees on a compass and the other at 200 degrees.
You have one VHF-HI station (NBC Real Channel 11). It is likely powerful enough to be picked up by your DB-8e. Certainly worth trying before buying anything (like an Antennacraft CS-600). Unless the Antennas Direct VHF Retrofit Kit made for the Clearstream series will work with the DB-8e. I'm not sure.
Wait for the experts to post.
Thanks Jake...will try the DB-8e. Thank you for the help!
thesoxwin is offline   Reply With Quote
