Old 9-Feb-2015, 3:22 PM   #1
BigDaveyL
Feasability question
Here is my TV Fool:
http://www.tvfool.com/?option=com_wr...2c152a3893b9e5
I have a Winegard antenna already up, along with a RCA preamp (to make up for 8-way splitter and long cable runs) and a Rotator. I have been happy with it so far and have the antenna pointed such that I can get the max. channels I can get at one time (I think we're up to 38 or something).
However, the geek in me would like to pick up channel 27 (click on pending) out of Canada. They show some programming (like some History shows). I can get this station no problem IF I rotate the antenna or just put a good enough antenna in a north facing window on the second story.
So my question is twofold....
(1) Can I just use a standard splitter to put in the signal from the second antenna to get 27? You know, for the wife acceptance factor.
(2) If I can do #1, is it feasable to get CBLT or CHEX (CBC affiliates) in order to get additional programming (like Hockey Night in Canada)? I understand I would probably need to put up a larger antenna outdoors (read: 91XG or DB8e)
BigDaveyL is offline   Reply With Quote
