Old 8-Feb-2015, 4:36 PM   #7
Ben Myers
KD3WB
Originally Posted by DaveBB View Post
I need some help here, my antenna worked fine. But now it works sometimes, then the next time I turn it on it doesn't work and then the next time it will work. This happens no matter what the weather is outside. I'm confused on what is happening here with it. Have a Channel Master antenna, and a pre-amp. and always got reliable signal. I would appreciate any help that you may offer to me. Thanks so much!!
Make sure all your coax connections are tight. Anything that blocks the DC voltage from getting to the preamp prevents it from working and can cause the kind of problem you are having.
Ben Myers is offline   Reply With Quote
