Old 7-Feb-2015, 12:36 AM   #1
DaveBB
Help, for some reason my antenna works then doesn't work then works?
I need some help here, my antenna worked fine. But now it works sometimes, then the next time I turn it on it doesn't work and then the next time it will work. This happens no matter what the weather is outside. I'm confused on what is happening here with it. Have a Channel Master antenna, and a pre-amp. and always got reliable signal. I would appreciate any help that you may offer to me. Thanks so much!!
DaveBB is offline   Reply With Quote
