Old 6-Feb-2015, 2:04 AM   #3
The ANT-4008 is really little more than a single UHF loop antenna, which will perform about the same as the UHF loop on a traditional UHF/VHF rabbit ear style indoor antenna. The addition of an amplifier doesn't add to the performance of this or any other antenna... Amplifiers are only capable of overcoming losses in cable and splitters on the output side of the amp.
Jake V is correct, if you want to see more than one or two signals, a larger antenna needs to be mounted outdoors, clear of obstructions. The Antennas Direct DB8E + Antennacraft Y10713 + RCA TVPRAMP1R would give you a very good shot at seeing some US signals in addition to the local signals.
