Old 4-Feb-2015, 6:31 PM   #12
timgr
Originally Posted by EmptyBox View Post
So, are you saying that if i take the TV and antenna outside and still can't receive any signals then a rooftop antenna probably won't work either?
It's a test that costs you nothing and, if reception improves significantly, will tell you a lot about what influences reception in your condo. The green channels are pretty darn strong, and you should get most or all of them with a simple antenna that is aimed properly and unobstructed by buildings or trees.
If you take the antenna outside and nothing happens, that tells you something too ... that most likely there is some other problem with the setup, like the TV or the antenna or the cable.
