Old 4-Feb-2015, 6:18 PM   #11
...are you saying that if i take the TV and antenna outside and still can't receive any signals then a rooftop antenna probably won't work either?
Almost. We need to be sure the TV that you're testing with works. The signals listed on your report should be relatively easy to receive if not for obstructions such as buildings and trees. If you still don't see any signals when testing outdoors, using a basic unamplified indoor antenna, I have to start suspecting a fault with your tuner.
Once you have proven the tuner is functioning at an average or better level, you can begin to trust it as a test tool.
