Old 4-Feb-2015, 4:47 PM   #20
DaveSmithe
GroundUrMast ... thank you again! Not preachy ... advice well given!!
Will definitely test before drilling ... my biggest concern is the fascia board not holding the bolts ... it was built in 1954
I have not yet been on the ladder to test the hardness/softness of that fascia...so wish me luck there.
I didn't even consider the 10' pole ... duh! That would give me plenty of room to put both on one mast ... especially since from the eaves mount lower bracket to the peak of the roof takes up about 2' of the mast. But will test several locations.
Honestly I hope that #3 will work out ... as long as there is enough clearance from the top of the DB4e and the Y5713 ... as long as the DB4e is not blocking line of site for Y5713, it should be OK, correct??
Hopefully will get this stuff ordered this week and have a good day to install it in about a week or two ... stay tuned!!!!
Now ... what antenna to order?!?!
DaveSmithe is offline   Reply With Quote
